Well after a couple days of fun at the dunes this weekend i blew the head gasket on my 400ex. Just a small oil leak coming from the left side of the head. So now im looking at options.
When i bought the bike i was told it had a 440 kit in it as well as cams. Would the cams be marked and be obvious when i start the tear down? And then i assume i can just measure the cylinder bore to find out if it actually has a 440 kit in it? What measurements am i looking at?
And then, I have no idea what im expecting to find once i start to tear this engine down. Would you guys recommend to do a full top end rebuild with the head gasket? Should i do timing chain and tensioner while its apart? And if it truly is a 440 kit, from my understanding, HG's are a fairly common issue?
I want the engine to be fairly reliable. Im looking for the best balance of power and reliability and im not afraid to spend some more cash if it means i can get a few years of trouble free riding. Would you recommend I go back to a stock bore and just put in a high compression piston and just do full bolt ons? Should i look into a 426 kit? Or will the 440 kit last awhile if its properly gone over? I want to stay with being able to use 92 octane pump gas as well.
Also, what sites to you all recommend for parts online?
