1 - 9 of 9 Posts
I'm pulling my hair out on my 98 Honda fourtrax 300 2x4 lost key so I hot wired it using to toggle switches it ran great I ordered a key switch for it and now I'm lost is my key switch supposed to have 2 hot wires when on n 2 hot when off
Did you buy an OEM master switch (key switch) that would have made it simple. Swap out bad harness for new harness.
You should be able to access the service manuals and parts links in my signature block below. Wiring diagram in the back though.
I don’t have a copy of the later model service manual
you can always pull the ignition switch out of the dash, and locate the numbers along the side, this number will give you the key code to cut a new key
Quote from Shadetree ^^^
I can't advise on the wires, I'm sure someone will be along who can, from now on do yourself a favor and write those 3 digits under the rubber key weather cap, make note... That rubber weather cap on some models (300) will NOT come off! Mine are c09 and a09, hopefully noone will get the idea to have copies of mine made....lol!
please remove your link in your sig for service manuals, the manuals are no longer around, thanks.
Hey Shadetree my
149330
Text Font Auto part Rim
link works for me don’t know if anyone else can see it but you’re the only one who’s said they can’t
No he's not the only one, I'd take a screen shot, but since they messed up the forums, i can't post pics, but..... All i see is a blank white page with the tab marked untitled .....
If you could access the links like i can —Here’s a pic of the schematic View attachment 149332
all I see on your sig links to the files is just like the Wilson ^^^ said, nothing but pics of folders, but can't click on them to down load, soooooo..don't know what to tell you ??.
1 - 9 of 9 Posts
