1 - 12 of 12 Posts
My issue is the plug that plugs into the my voltage regulator was destroyed an I need to know is there any order in the pin out of the three yellow wires that comes from the stator. I have asked several shops an none of them have been able to answer this an I was hopping that some from this forum could any help would be greatly appreciated.
Thanks
Well, what are you working on? There might be a fourth wire (different color) depending on the system. Do you have a used plug that you intend to wire up (soldering & weatherproofing) right, so you can simply plug it in when you are done? Do you have an ohm meter or a multimeter handy?
Here ya go... I looked up your bike from your previous thread (400 Foreman right?) on this issue, so then I looked up the ignition & charging circuits in the FSM for you as well.
The stator is wound with a Star topology, so all you have to do is match any yellow wire coming from the stator, with any yellow wire going to the regulator/rectifier. See the attached images...
yer welcome... fuggedabowdit... don't be like the hack who made this mess for you, fix it right and have some more fun!
If I’m reading correctly, retro looked it up and found out that as long as a yellow wire goes to a yellow wire then that is fine. You should have all yellows, yes?
So yellows to yellows, any order. Any other colour to the matching colour ;-)
Hi: This should help you out.
Reactions: Goober
Hi: Here you go
1 - 12 of 12 Posts
