Working on a 1999 Honda foreman 450 s does this piston gap look right? It was smoking bad but found issues with valves and it had 100psi of compression. Guy i got it from said it has a new wis. Piston and rings
Great idea to keep the same piston if it's not worn and the original size.G&H does a good job:
Cylinder & Head Machining Service - G&H Discount ATV Supply
Or you could just buy a new OEM cylinder since the new Wiseco piston you already have appears to be for a standard bore. Its your call...
oh yeah...lol, that bottom ring gap is wayyyyyyyyyyyy too big !.So update i got a new 90mm oem cylinder now heres how the rings are the top ring is 90.25 bottom ring is oem 90mm does the 90mm ring gap look to big still?
well, I can tell you this, those rings won't work. If you had this cylinder bored over, and bought this piston kit ?, surely you bough the piston to match the bore...right ?. when I have a cylinder bored over, I always have the correct piston kit on hand to match cylinder. those rings wont work, which tells me the piston won't work, because it does not match your cylinder.Its a oem 90mm cylinder i have a wiseco 90mm piston and rings which is the bottom ring
