I've been pulling down a couple of 300 rear ends to rebuild. I have one that has good teeth on the ring and pinion, but there is some wear on the pinion gear where it rides in the needle bearing, which results is slack.
The Boss Bearing rebuild kit came sith a "pinion repair sleeve" and apparently you machine down the pinion and slide the sleeve in place.
Anyone do this, and if so, how did you do it? I'm guessing I'll need a lathe, but was wondering if there's a ******* way that would work.
https://www.thebigbearingstore.com/ir10x14x16-honda-repair-sleeve/
