2005 Rancher 350 2x4. compression is good, good spark, plug gap is correct, fresh gas. Valve clearances not checked but don't rattle much.
Just started working on this new project. Engine turns over, but won't run. Was running since I have had it, but ran very rough.
So my issue is this. I wanted to know where the pilot screw was set, but it's like there isn't a pilot screw. I am trying to adjust it on the bike, so I can't see what is going on, but I insert the small screwdriver where the screw should be, and the screwdriver goes in about 1 1/2 inches without touching anything. Is the screw that far up there? Could the bike run without a pilot screw? Wouldn't fuel leak from there if there wasn't a screw?
