Just throwing pictures up of how I did mine. I wasn't into using one of the Spacers that you epoxy on and ruin the carb for anything else, or movingy air box forward about 1 inch and making that work. Both of these methods also both leave a little bit of the intake tube where it necks down smaller than the 450r carb opening. So in the pictures you will see I cut the intake tube back to where it is shaped like an oval instead of round. I then took a piece of 2 1/2 pipe and used a hammer to make the one end oval shaped like the intake tube. This left clearance to go over the frame behind the carb. . Then I used a 2" rubber boot to attach the other end of the pipe to the carb. Cheap, easy, can't leak, and it takes that small bottleneck out of the intake tube. Just a different way of possibly doing it for future swaps. Thanks to everyone that helped with my swap.
