Hey guys as I posted earlier I purchased an 03 350 rancher es Looks in very good shape, however it has the dreaded ES problems and is currently stuck in reverse. I did a bunch of searching and watched youtube videos but wondering what you guys think my course of action should be as it seems like it could be a number of things.
When I turn the key the R comes on and if I try to shift the motor makes a noise but nothing happens. It only makes a noise in one director, not the other. If I try the manual shifter, it doesnt work either. If I go to the left I can actually hear the motor making a noise I think? Is this right? Ive never owned an ES model before.
I also cant attempt to start it because it is stuck in reverse.
Should I try harder to manually shift? I am scared I will break something.
Ive seen ppl say its the shift plate, the module the angle sensor, the gears from, the shifter motor, the shifter motor itself. Any help would be greatly appreciated. Just wondering what I should start checking first.
Thanks
Thanks
