i have a Honda foreman 400 4x4, the top of the engine over heats but the bottom is normal temp, changed the fan control unit, and the spark plug wire,runs fine just over heats. Any suggestions .1998.
fan coming on ?. bad fan if not ?, or oil temp switch wire came off or bad oil temp switch ?.
You should ask the guys over at atvhonda.com.
Recently changed oil? Filter reversed?
Pop valve adjustment covers and see if you’re getting oil up there
