I'm in the process of rebuilding a 2000 350 rancher es 4X4 and got the pushrods mixed up from the original position.:frown: I noticied the manual states replace the push rods in the original hole it came from. Will this cause premature failure? What do yall recommend I do? I also noticed the valve adjuster screws looked worn with sharp edges, is that normal wear and tear? I was not doing anything to the head since the valves looked good and passed a solvent test. I'm going to replaced the valve seals since they came in the top end gasket set. Thanks for any advise....
