2002 Honda rancher 350FE. Okay got the OEM carb, installed would you recommend turning gas off and running the bowl dry or just shut gas off when not in use. Trying to avoid the needle valve leaking for as long as possible. Been through brakes, wheel bearings, fuel system top to bottom, new OEM carb, changed all fluids. Now just crossing my fingers I get a fair amount of use before anything else shows up.
this might come down to HOW long does it sit between use?
as if you run things dry and it sits for months or weeks, it can dry things up in a carb and that alone can cause issue's
so, double edge sword here IMO
if it gets used rather often , I would go with running things dry, peacock off and run till it stoop's or JUST before it starts to idle up due to low fuel! this way there is a LITTLE fuel in there but not much!
for me ?, if I know it will sit for awhile ?, I run the bowls dry, crank it, let it run until it stops, turn the fuel off. add sta-bil to the tank, top the tank off.
Don't ever put any cheap gas in it. No ethanol ever. Keep the fuel fresh in the tank, always less than 30 days old. Turn the petcock off when you park it for the night. If you're gonna store it for more than 30 days, drain the entire fuel system. It works for me, I don't have any carb troubles on any of my equipment. And I have a lot of VERY old stuff.
