if that oil is wet clutch approved you will, be fine on the oil, if NOT drain it before you cause an issue
and JUST so you know, DRAINING your oil after sinking an ATV< doesn't mean its FIXED
far too many have just done that and in a short while in need of motor work
dirt and crap that goes in with the water never really ALL comes out by just draining or even flushing the motor
your doing what is called gambling that it will hold up., by just draining and flushing a sunk motor!
Only one REAL way to do the job correctly, and thats split motor and CLEAN
' anything less is a GAMBLE your taking
sorry, its just a fact!
