Ok, just bought a 2002 TRX 450 foreman FM. Stone cold start, oil temp light stays on. I’ve changed the oil and filter (Yes filter in the correct way, hehe). I am assuming it’s oil sensor. It unscrews easy enough (drain oil). Is it hard to change wire end ? Maybe wire is shorting out? I’m new to this any advice would be awesome! I’ve ordered both oil sensor and fan switch module, as I’ve read they are both common culprits for this problem. Advice on the how to is most welcome. Thanks
