What year? Are you checking level properly? Those early Ranchers have a fill port on one side and a dipstick on the other. You pull the dipstick wipe it and reinsert without screwing it in—rest it on the oringOil problem Oil is not returning to my crank case after I warm up my engine on my Honda rancher even after for five minutes it’s nothing on the stick
I don't think this is a dry sump engine. OOPs!. LOL I think it is a dry sump. Oil fill and dipstick are two different areas? My 2008 and 2014 Ranchers aren't that design. What's up with that?Hi: Checking Oil
ENGINE OIL
LEVEL CHECK
NOTE:
Check the oil level after starting the engine and
allowing the oil to circulate through the engine thoroughly.
II is especially important on a dry sump
engine. due to the comparatively large volume of oil.
Do nol snap the throttle while idling or Ihe oil level
reading will be inaccurate.
Remove the left side cover (page 3-4).
Place the vehicle on level ground.
Start the engine and let it idle for 3 - 5 minutes.
If the air temperature is below 10"C (50"F). let the
engine idle for an additional 5 minutes (a total of 10
minutes).
Stop the engine and wail 2 - 3 minutes.
Remove the dipstick. and wipe it clean.
Check the oil level by inserting the dipstick into the
engine without screwing it in.
The engine contains a sufficient amount of oil if the oil
level is between the upper and lower level marks on
the dipstick.
