back round, this is a 2002 400ex punched out to a 426, we took it apart because of a transmission problem, rebuilt the motor had no issues during assembly. we started the bike for the 1st time and it fired right up, let it idle for about 5 minutes, all is well, went out and rode very mildly check all the gears and such for about 10 minutes, when returning to garage found oil dripping out of the air cleaner on to the back of the bike and not a little but allot ie 1/4 to 1/2 a quart according to the dip stick, also found that the breather tank was full of oil (this is the little white tank that is mounted to the side of the intake boot) , shut the bike off and let the breather tank drain back into the motor, took air cleaner off and started the bike back up, put my finger over the breather tube and there is just a wisp of air ( so this test eliminated ring issues and blow by) checked the oil in the tank and found it to be low. also because it was a new motor we filled it out of a gallon jug so I know I put 2 1/2 quarts of oil in the motor ( bike has extra capacity oil tank not stock so this would tend to eliminate the theory of over filling engine with oil)
the only 2 things that I have been able to come up with that could cause this is,
1) scavenger side of oil pump failure or blockage causing excessive oil in crankcase.
2) damaged gasket where oil galley goes thru the case halves over the top of the breather chamber causing an oil leak directly into the air chamber where the vent tube mounts to the engine.
has anyone had a problem like this and if so what did they discover?
