Hello to all. I'm new here on the forum. I Just bought a used 2006 honda fourtrax 350 es. Decided to dump the oil so I removed the drain plug and there was no seal washer on the drain plug. So i finished draining the oil. Then I thought I would put the plug back on. Now the bolt won't tighten I'm worried that I mightve stripped the threads or do I just need to find a seal washer and it will tighten back up. Hopefully someone can point this newbie in the right direction.
