1 - 17 of 17 Posts
It's quite simple go buy a new oil filter it will say "THIS SIDE OUT" on it on the right hand side of the engine is a round louvered cover held on by three 10mm bolts, on the bottom of the engine is a bolt in the center of the crank case that is the drain.. do not overtighten it when your installing it or you will be posting up "How do I fix a stripped drain plug?" remove the cover on the side gaining access to the filter remove and insert the new filter put the cove back on making sure not to damage any gaskets or O-rings. tighten everything back up and grab a couple of quarts of approved Honda oil I use GN4 10w30 and fill it to the required level. Start it up ride around the yard easy stop and recheck top off if needed...Your done
yeah if you want an inaccurate reading. screw it in ..
KK thats what i do someone told me that and i guess that little of a difference really wouldnt hurt anything but i mean did that not sound really dumb? I thought so!
K i now have a question that someone told me one time u check ur oil without screwing in the dip stick is that true?
I don't know about all hondas, but on a 300EX, you are NOT supposed to screw it in. You just put it down in the hole until the threads tip. Don't screw it in. Make sure it is perfectly level, though, or your reading will be off.
Trying Pain's instructions out. I didn't crop this time, but I will the next time.
I tried to post the rest of the oil change procedure, but for some reason, i can't get it to work. I uploaded it to Imageshack. I copied the link and tried to insert it as an image in the post and it wouldn't work. It worked the first time. I can see the link in the box, but when I click on save, it just puts my signature on the post. See I can post them as attachments.
Let me try this again. It still wouldn't work. It shows the link to the picture at Imageshack with on each side of it, but it don't show up when I click on save. I can't figure out why it worked the first time I did it and now it won't work.
[IMG]http://img69.imageshack.us/i/oilchange1.jpg/
I scan my book and save them to a file then I upload them to my picture album you can go to my profile and see my uploaded manual there when you do that you just highlight from "www. to the end right click copy then I usually have to forum windos open so I can go back and forth then I simply click the yellow box up above this box and paste...you done... like this. Make sure you copy the picture URL one.
OK, that worked, Moose. Thanks.
1 - 17 of 17 Posts
