1 - 15 of 15 Posts
Since my last oil change I rubbed oil off on my finger from the dip stick, and it felt good and clean. But I decided to change it today since my last oil change (2014), and I found it was all brown and broken down, I'm going back to my original schedule every 6 months. I'm embarrassed to say I let it go this far. A photo is here. :eek Yea no more 2nd hand advice for this guy. Lucky had no water in it. Synthetic oil does wonders I'm suprised it wasnt totally totally broken down. I caught it in time.
The worst oil i ever saw was from long oil change interval. Leaving oil in an engine that long period is a huge risk. At the very least i would change it once a year. Good news is you ride a honda. And i have seen first hand a honda motor run with zero oil for a few hours and just need a topend rebuild and a new oil pump. Everything else was in spec perfect. But i dont ever suggest playing with fire. My buddy got really lucky on that one.
Reactions: jdp
Yep that's what im gonna do is go back to my change interval of at least 6 months, I took some time off to take care of my cousin and it wanst ridden much since I left, except whenever I'd come back up to Branchland. Going back sunday to take care of my cousin, good to know I caught it in time. Got some time so I did that and even cleaned the garage for my uncle to sort stuff. It was a MESS. Now you can walk around it it and not stumble over stuff.
Im sure that will make your uncle happy! After all that work you deserve to go ride that honda lol!
Yip :D Sure is Lol.
I agree, a service interval of 6 mo would be good. At each service, I would change the air filter and differential oils as well.
Discussion Starter · #8 · (Edited)
Is there a way to get that air filter off without tearing it or crushing the fingers? I crush and pinch mine all the time, I wish they would put that top lip on the cage a little thinner so a man can slide the filter on.
I remember having an issue trying to put that air filter on but after messing around with it I eventually got it on. I think? I must've had a couple (or 12ish) beers while doing so.
Infact, I should check my air filter tonight... Hopefully it's on there.
That's where I'm at, about every 4-6 months, depending on how much I ride.
Reactions: jdp
Discussion Starter · #12 · (Edited)
I changed the rear diff oil after the air filter. I didn't have the Honda GL5 oil so I used CRC Sta-LUBE brand GL4 Hypoid 85-90W. :D
4 times a year for me, mostly because I ride at off-road parks in the mud and water etc. It's better to be safe than sorry IMO.
Reactions: jdp
Discussion Starter · #14 ·
Yip all done as of about 20 minutes ago im gonna say.
I change my oil at the very least 3 times a year and if run in a lot of hot weather with slow speed riding where on a air cooled motor runs even hotter, I change it twice in summer and I even run a manual fan.. I change rear diff 3-4 times of year and front once or twice depending on the amount of riding..
1 - 15 of 15 Posts
