lots of great oils out there today, and suggesting "X" brand tends to starts long treads on MY oil is better than your oil and or just ramblings
as long s the oil meets the wet clutch requirements, any oil is good to be honest as long as you change it before it goes bad!
I personally been using amsoil 4stroke 0-40 for 20 yrs in my atv and been very happy, but I admit there are many oils of just as good qualities
I am also a guy that prefers to use ONE brand weight oil and stick with it for life of motor!
not sure what could happen if you mix things all the time, as I know in most chemicals there are reactions when you add and mix them! most likely NOTHING bad would happen, but in life when ever I can try and rule out possible problems I tend to do what I can!
not about brand loyalty really, more along the if its works well why switch and or risk a side effect!
I again am also a guy that changes oil more often than more too! but also bene known to be hard on motors more than some as well, so, peace of mind has a price tag I guess LOL
