What is “normal” as far as how far back the front brake lever travels when the brakes are applied? This is an ‘88 TRX350D with drum brakes.
I’ve replaced the seals in all cylinders and bleed probably 2 pints of fluid through it. The handle stops about 1/2” before it hits the handlebar grip but I can pull it all the way to the grip without much effort. The brakes do work, I’m just wondering if I should have more lever. If I crimp the hose it’s hard as a rock with very little movement.
Anyway, just trying to get a baseline fir what to expect.
