1 - 12 of 12 Posts
So I have never owned a 4 wheeler, and I happened to be riding the other day and I looked at the mechanism for the rear brakes on my 400ex. How do you add fluid to the system for example when you change the rear pads?
haha, no, I figured I should make sure I know how to ride it and don't flip it myself before I go replacing parts. So far I haven't had much time to ride, I did however find time to bust my a$$ the other day when I found out its not a good idea to try and pop a wheelie full throttle in first gear from a stop. Turns out the entire 4 wheeler will go completely vertical, dump you off the back, and then continue going on its own haha!
I did that on the MX track a few times right of the starting line.
Discussion Starter · #10 ·
Here is another noob question. I was screwing around with the parking brake the other day (out of adjustment or something becuase it doesn't work haha) and I grabbed hold of the rear rotor and I could wiggle it from left to right a little bit. Is that normal?
Um No I don't think it's supposed to have side to side motion.
1 - 12 of 12 Posts
