I am working on 2006 Honda trx350 rancher for a friend. I am having a problem with it not sparking. I have been through the trouble shooting in the manual and searched online for any other info to check. So far this is what I have done:
1. Checked the kill switch which was good
2. Check all connections they were all good
3. Checked the pulse generator with a peak voltage adaptor on a multimeter and the voltage it was cranking was around 5 volts and the manual said the minimum was .7. So I don't know if that is too high or not.
4. Checked the charging system just to make sure by checking continuity. It all checked out.
5. Checked the gear position switch. It was also good.
6. Got a new spark plug along with a new ignition coil.
7. Then I checked the voltage going to the ignition coil. This is where it kinda gets weird. So when the ignition coil is plugged in there is only about .04 volts going through the black yellow wire when the engine is cranking over. But if I unplug the coil and just put the multi meter into the the wire it reads 120 volts constantly.
8. Checked fuses also all good.
So after checking all these things it is still not sparking. I have a spark tester that I am using and also just touching the spark plug into the cylinder. But when I have my spark tester all hooked up when I turn it on the tester flashes but doesn't do anything else. The only thing I can think this would be is the ICM (cdi). But there is no way to test it that I know of other then getting one that works. And I know no one that has one that I could borrow to swap in. Does this sound like this could be the problem, or is there something I'm missing?
