1 - 1 of 1 Posts
Hi peeps. I’ve got an 02 400ex that doesn’t get any power (headlights, neutral light or e-start) when turning ignition key. I can start it via jumping the solenoid and lights turn on. I can kill the motor with ignition key once it’s running. Do I have an ignition problem, a bad solenoid or something else?
Also, what circuit is the fuse on? I can jump the solenoid without the fuse. I thought the fuse completed the circuit that the starter was on? I did notice that one of solenoid jumper wires that goes into the fuse was sitting a bit higher in the connector than the other one. Is that normal?
Hand Automotive tire Finger Bicycle part Motor vehicle
1 - 1 of 1 Posts
