I recently purchased a 2013 Honda Rancher 420 for $500 from a guy who was moving out of town and needed to get rid of it. He said that the clutch went out and he replaced it and he must not have put it together right because he rode it down the road and the new clutch went out as well and he had to push it back.
Anyway I have been trying to get it running. When I turn the key the lights on the dash come on, but the neutral light doesn't come on and it says "-" under gear position. I know it is in neutral since I rolled it off the trailer when he dropped it off at my house.
What is likely to be the culprit here? After some googling I noticed some people saying the "neutral switch" or "neutral safety switch" could have gone out, but I can't figure out if the ES models like mine even have this switch. I also found some mention of a "gear position switch" which should be on the inside of the rear crankcase cover, which he would have had to remove to change the clutch. Also some people were mentioning an "angle sensor" which would be on the rear crankcase cover.
Any guidance would be greatly appreciated.
