I have been 2 days straight trying to figure out what is keeping my 1995 Honda Fourtrax 300 from not getting any electrical power. It has no lights on the handlebars, no headlights, no brake or taillights I have used a jumper on the diode, rewired the safety switch(and the neutral light will not illuminate when it is grounded). I have put hot directly to the neutral switch light and it will light up for just a second and go off. I have replaced the solenoid, replaced the key ignition switch last year. Both wires on the starter are testing as grounds, that doesn't seem to be right, is it? the fuse on the red wire under the seat is good, it does have power to the key switch as well. The starter will turn over by jumping the solenoid. It will not start by kick starting it either. I sure hope someone can help! Thanks in advance!
