I have a 2000 Honda Fourtrax 350 es. Lately I have been having some issues with the brakes. It is getting too sketchy to ride it.
So I only had rear brakes on my bike(one of the front brake lines broke and all the brake fluid leaked out so I have no Front brakes) My problem started a little while after I bought the bike. The brakes wouldn't stop me as quickly as the did when I bought it. They kept getting worse so when my u-joint broke and the bike went into the shop,i mentioned that the brakes weren't that good so the guys there must've tightened the wingnuts on the rear brakes because that fixed the problem was fixed when i got it back.
After a while the brakes got bad again so i was messing around with them and found the wingnuts everyone was talking about and tightened them. This fixed the problem for a bit then I had to tighten them again and again and again until i cant tighten them anymore.
I need some help. I have tightened the wingnuts that everyone talks about all the way in and my brakes don't work anymore.
I know that my rear brakes are good because you can roll the atv and then push on the rear brake assembly where the cables attach to and it stops the atv on a dime.
I researched online and heard you should oil your brake cables. I looked up a proper video and did exactly what they said to do. The brakes still don't work for me.
When i had the brake cables off i inspected them and they look perfectly fine just a little dirty so I don't think I need to replace them
I have tried everything that I have heard of working and am desperately in need of some help from someone who knows what they are talking about. Thanks everyone in advance
