Hi! First post here!
Having previously owned a 96 TRX300FW 2x4, i recently bought a 97’ 4x4.
Looking for a bit of advice on maintenance and upgrades.
So, as far as ive concluded :
Engine Oil : 3L of 10w40 Honda GL3?
Front and Rear diff oils? I read somewhere about replacing the oil with grease, is this a viable thing to do?
Any help / tips on maintenance and upgrades be appreciated!
Thanks!
Thanks!
I use BelRay 80W 90 hypoid oil in the diffs and the gear case attached to the engine.
You should see a link to the service manuals in my sig block. Always best to read over the specs, and i usually stick with oem replacement parts—I avoid aftermarket because of no-name reliability or performance concerns
I stick to manufacture recommended lubes and greases; that said members here will share what they use. The intent is to exceed the standard or meet a special or extreme application.
Thanks!
3L (3.2 qt) is too much oil. You don't want to overfill it. According to the manual:
Only 2.38 qt at oil and filter change and 2.3 qt after draining
For Rear Final Drive you use 3.0 oz after draining
For Front Differential you use 6.4 oz after draining
Both above use Hypoid gear oil, SAE #80.
For Front Gear Case you use 6.4 oz after draining. As @Goober said, above.
I cannot recommend using grease, but some people do it, especially those who ride in deep mud and water.
Hey guys back again, just gone to replace the clutch cover gasket, all is well but i cant seem
To work out the correct fitting/setup procedure for the clutch control arm? Anyone got any tips/guides on how to do it as it all sort of came off with the clutch casing.
I have attached some photos.
There is a arrow on the case and a dot on the arm , make them line up , it looks like you might be off a bit from the pic -------- I have the cover off my 300 right now ----I n=know from past bad experiences if you are one click off it will shift up but not down or vice-versa
