1 - 1 of 1 Posts
Hello all! 92' TRX300FW With the key OUT of the ignition, when you connect a charged battery, the starter engages. The starter does NOT disengage until you disconnect the battery. I borrowed a known good solenoid , same thing takes place. The way I understand it from the manual, the solenoid requires 12 volts for continuity? No 12 volts, no continuity thru solenoid? So I'm leaning towards a short in the circuit(wire(s)) between the solenoid and the push button? SOS:wink
I searched & read before posting, this one similar post was never finished or the fix was never posted.
http://www.hondaatvforums.net/forums/honda-trx/54409-honda-fourtrax-300-starter-problem.html
1 - 1 of 1 Posts
