Hi guys new to the forum here. A couple weeks ago my starter kept trying to start the engine on my 1999 Honda trx300 2WD even after it was running until I disconnected the power wire from the top of the starter.. I decided I’d go ahead and change the starter and solenoid. After replacing both parts, I have no power to any of my lights ( headlights, neutral, reverse, oil pressure). The battery is fine it’s reading 12 volts and my winch is working fine because it’s wired directly to the battery.. kick start won’t even crank it.. I have continuity at the solenoid when I press the start button.. I unplugged the harness for the voltage regulator/rectifier and tested continuity on the three prongs on the wire going to the regulator and I have no continuity there at all.. does this pretty much mean I just need to replace the voltage regulator/rectifier, or can the ignition be the issue? Thanks in advance
