Over the last 3 to 4 weeks I have been fixing up my old 1998 Honda fourtrax 300. It's in really great shape for it's age. I've replaced the rear end, added a 1.5 inch lift, new super grip rims and 28" interco vampire edls. It's been on 2 rides since I added the tires and rims and I have noticed some lose of power in a few situations but nothing to bad. I know the tires are rather large for the 300 but for the riding I do they do real well. Yesterday and today l have started to add some performance mods to it to try and get some power back. I added a K&N filter and pre filter. Rejetted the carb. Installed a high lifter heavy duty clutch spring kit, and when I tear the front end down tomorrow I will install a spool locker. This is the first time I've ever done any work to an atv so Im trying to make sure what I've done so far is right. On the carb jet I used the 128 main and the four wheeler seems to run fine. It idles great, starts from cold and hot, and idle to Wot feels good with no stuttering. Is there anything that I need to check to make sure I'm using the right size jet? Also I've never installed a clutch kit Nore driven an atv with one. After the installation it waits till you get to a certain rpm before the clutch grabs and pulls which feels good and feels like it has more low end power that way but I'm just making sure this is right. Last question is on the snorkel. I used 1.5 inch pipe and I'm wondering is this a good size for the 300 or should I have went with 2inch since Im jetting it? Thanks for any responses.
Edit to add more info in the jetting. Not sure if this matters but I screwed the air/fuel mixture screw in and backed it out 2 and 1/2 turns like the instructions said.
