Hey guys new to the forum don't really really know how this works But wanted to join cause I need advice and dos and donts I have an 02 rancher 350 and I got it about a month ago and have put a 2 inch lift on it have another but dont know if I can put it without gorilla axle speakers and fixing to add another 1000 watts to that setup and a light kit and winch I have mud tires but have to Get conversion spacers and have it snorkeled but no lines run haven't had time and dont really know how to do it and put light bars on front and back and little things like that but I like it and I think looks good but need some advice
You don't need gorillas for a 2" lift.
For the snorkel you need to run 1.5" pipe from the airbox, then for vents you'll need the front and rear diff vents, carb vents (2), fan vent, front (2) and rear brake vents, and the gas tank cap vent if your going really deep. You'll want to make sure your check valve is working properly on the bottom of the carb also, and I'm not 100% sure if the crankcase vent goes into the airbox on the 350's or not but I would get a longer hose for it and put a few coils in it then put it back in the airbox, or run it to the top of the snorkel, but that's not really ideal.
