Hi,
so I just bought a three wheeler basically because I wanted to put around the yard. Needless to say it won't start. I have run into serious issues even gathering data. The frame has no serial number that I can see. The bike is stripped down to the bare minimum. So if anybody that can help reads this, I would be grateful.
The guy that sold it to me said the motor was "a 1988 250"
It is a pull start.
There is no spark.
The wiring was a ball of wire and duct tape, so I cut it out to a component level.
Coil- there was one wire going to the coil. I read the coil and got .8 ohm from the primary to the core (ground), 4.11 kohm from the secondary (plug boot) to the core, 4.11 kohm from the primary to the secondary
CDI unit- There appears to have been 6 wires originally but I could only find 5, and one of the five was only stuck into the connector (no pin) * visual inspection of the CDI showed only 5 spades for a connector (the missing spade matched the wire with no pin. Where the wire was completly missing from the connector it appears the wire corroded (green dust)
Coming from the left side of the motor there are three wires. All the drawings I can find on the web show four wires. I have a general drawing that calls it "pulse generator", but there are only two wires to that. Is the third wire possibly the exciter coil or neutral switch?
So: Can I verify the CDI with a meter?
Does the readings of the coil indicate that it is good? I think so.
As there is no ignition or engine stop switch I don't see the need for it coming out of the CDI. Is that correct? I can just choke it out if I ever get it running.
If someone thinks they can help I can e-mail pictures.
If your reply is just sarcasm please be original.
It is a pull start.
There is no spark.
