Hello!
I'm hoping that someone can help me on this issue.
I was out riding when all the sudden my 2007 Rancher TRX400FA would not shift and started giving me a problem code of 12. After following the instructions from the Hondamatic in the service manual, I replaced the ECM. After replacing the ECM, I started it up to perform the initial setting procedure and it popped another 30 amp. I put in a new one and went through the Initial Setting procedure. After completing the initial setting procedure, I took it for a test drive, it would not shift and gave me a Problem Code of 5. When I disconnected the Angle Sensor, I checked the voltage on the connector and got 0.
Does anyone know what the voltage should read on the connector? Also, do you think that I blew the ECM after I installed it and then blew a 30 amp? I'm hoping that I do not need to purchase another ECM after just installing a brand new one.
I would appreciate any help!
