Ok first off I bounced on and off this forum for long time getting answer's. I finally made a account and joined up. My very frustrating question is this.
I have a 1987 trx250x and love this thing. I just don't understand it anymore.
So basically I can start it real easy normally 2-3 kicks warm and 5-6 cold. It idles great sounds good and the power is there but, when I hit the throttle half to almost full it does a rev like thing. To break it down it is like when your in reverse and you full throttle and how you get that reverse rev well that's exactly how it is when i half to full throttle. Now I cleaned my carb 3 times and swapped carb still does it. Tonight I took off the snorkel from carb to air box and it ran a tad better but still did it. I noticed that when I rev the bike and watched the rear of the carb it looked like it was spitting a lot of gas. If I take the carb off you can see some fuel sitting right there in the intake around the rubber mount. I thought it could been the float but, when I tip her back fuel flows out. I want to say carb but, two carbs I dunno. Any help is appreciated.
O to add to this the quad was fine all summer till the end and then this started.
Anymore info you need I will get it. Like I said it runs and idles like a champ and half throttle the power is there till a bit over half then it sounds like there is a rev limit on the thing.
