Hey guys,
So my quad needed new front brakes. Originally I bought the pads, a new master cylinder and just replaced those but then I noticed that the wheel cylinders were bad and only one side would move. So, I replaced the wheel cylinders today on both sides and cleaned out he small short lines between them. My problem is that the brake handle has zero pressure. None at all. I spent about 3 hours bleeding in all different ways. Vacuum pump, pumping handle, gravity bleeding...and now when i open the bleeder screw i get a nice steady stream of fluid coming out and no air. Still not pressure though. I am at wits end and thought I would ask if anyone has any ideas. I checked all of the fittings and there are no leaks anywhere. If I pump with the drums on I can still turn the drum with my hand so it doesn't get very tight. Also, with the drum off, only 1 wheel cylinder on each side moves...not both. Any ideas would be great!! I am starting to think my new master cylinder is bad....literally went through a bottle and a half of brake fluid today :crying.
