i ended up with a free 2001 honda recon that needed serious help, i'v replaced all the bearings in the front and rear end,and tie rod ends, and also converted the front over to disk brakes. but now im working on the engine ive installed a oil cooler on it, and rebuilt the entire engine from top to bottom all new bearings, and piston, timing chain, rings, and so on, but can't get it to run right.
i know it is in time checked it twice, it is firing, and getting gas, when i start it it will run great at idle, but when i give just a little bit of gas it will start cutting out and serges unless the choke is on, but when it starts to rev up with the choke on it will flood unless the choke is off, so i cleaned the carb and re jetted it, still ran the same so i bought a new carb, and it still runs the same.
and on a side note i did install a snorkle on it, but right now it is uninstalled and the air box is out of it so i can work on the carb easier, but dosent change how it runs at all. i have checked the compression and it is pushing 170psi checked it 3 times to be sure any ideas?
