AMSOIL Quickshot SE is a premium fuel additive formulated to thoroughly clean and restore peak performance in small engine and powersports equipment fuel systems. It also stabilizes fuel between uses and during short-term storage periods. Its revolutionary technology focuses on three major fuel-related issues plaguing small engines and powersports equipment: ethanol, water and dirty pump gas. Quickshot SE is recommended for use in all two- and four-stroke gasoline-powered engines
Click Here For More Info
Click Here for Product One Voice, a question and answer document on this new product.
Let me know if I can help you with any AMSOIL products.
Mark
What does that stuff run a bottle?
One of the biggest advantages of AMSOIL Quickshot SE is that it helps to prevent Phase Separation of Ethanol. Ethanol has a weak bond with Gasoline. One of the downfalls to ethanol is it likes water. If ethanol absorbs enough water it will cause Phase Separation and will float to the bottom of the tank.
AMSOIL Quickshot SE is designed to keep water dispersed throughout the tank, moving it out as a normal part of operation and decreasing the chance of ethanol separating from the gasoline.
Short term is going to be a month or less. Long term is for seasonal or extended storage like putting your lawn mower away for the winter. For the long term I would recommend the AMSOIL Gasoline Stabilizer then treat with the clean up dose prior to using after storage.
