1 - 20 of 33 Posts
Welcome to the forums.
Welcome to the forums!
goodluck and wlecome to the forums
Discussion Starter · #9 ·
its in great shape other than the motor. I opened the motor up and the piston is trashed!! The local machine shop is going to clean up the cylinder and I will add a new piston with pump gas friendly compression. They are going to do a valve job on the head as well as some port and polish work. I figure mine as well do it right while I have it apart. Debating on sticking with the stock cam for now due to budget reasons... Am I going to notice a performance gain with the new piston and head work? Or should I do a stage 2 piston to realize any real gains?
Make sure you check the rod bearing before you do all that work to it. Try to move the rod up and down and watch for play at the big end of the rod. A little side to side play is normal, but any up an down play means your rod bearing is bad.
Discussion Starter · #12 ·
Well I got the cylinder to my machine guy and it was a bit chewed up but he was able to use it. Did some port work to the head and a valve job:
Went with a Wiseco piston kit (10.1)
specs: 86.0 mm Bore x 70.0 mm Stroke
Im kind of new to this.... So is my displacement still the same as stock with this piston?
I am going to re-use the stock cam for right now due to budget issues. THink I will see any gain with the port worK?
I'm sure there are a few people on this site with some trophys like that.
1 - 20 of 33 Posts
