IIts a 1987 trx 350 foreman,does anyone know were its neutral safety switc is located? Not neutral lamp not illuminated in neutral and key on.
Under a small cover behind the right footpeg.
It will not start unless the connection is good so could be a burned lightbulb
if won’t start more likely the neutral wire is Broken at the switch end or behind the right side cover
Download the service manual from the link in my signature
right lower side, behind metal cover, both the neutral and reverse switches are right there tied together with rubber cups. BE CAREFUL WHEN PULLING THE CONNECTOR OFF !, THEY WILL SPLIT VERY EASY FROM AGE !.
