1 - 1 of 1 Posts
Clutch worked great prior to maintenance. I have a 1999 TRX400EX and disconnected the clutch cable at the lever on the RH crank case when I re-built the top end. Got all back together and when I reconnected the clutch cable to the lever on the right crank case cover. In connecting, I swung the arm CCW and connected the cable (not sure why I did that). When I determined was wrong, I disconnected the cable and rotated the lever CW and connected. Now the clutch will not engage and has no spring back action to return the lever. In neutral I can start and with clutch engaged, stalls when I shift in to 1st. I then manually operated the clutch lever on the R/H crank case but same results? Did I do something when I turned the lever CCW? Disengage something and/or dislodged something an the spring and need to replace and lever reset? Need some advice...
1 - 1 of 1 Posts
