i have a stock 1987 honda 125 atv and need an inner tube for a really chronic back wheel leak. presently, the atv is in mexico and the tire size i wrote down is 22 x 10.8.
is this all i need to get an inner tube?
the web sites i've visited so far have many other numbers as part of their tube id.
thanks, higado
Welcome to the forums. I would think the tire diameter, width, and rim diameter would be all you would need to know to get an inner tube.
higado depending on how long it takes to go flat you can put liquid dish soap inside the rim and it will slow the leak down alot of drag racers do that you can also use condenced milk but dont let it freeze and slime is really good hope that helps ya
slime wont help the bead seal nor sidewall cracks, only holes or cracks on the tread. i used tubes in mine works great all you need is tire diameter, width, and rim diameter
