1 - 2 of 2 Posts
So I have recently just replaced my bottom end right crank case cover due to chain damage... I had the Honda dealership do it since I didn’t have the guts to tackle the job myself, I would assume the dealership did everything correctly after the 1300 dollar bill as well as there reputation to be very efficient in their work.. long story short, I get the motor home, get it bolted back down into the frame and start to connect all the components when suddenly I realize that I can pull my clutch lever/arm to attach it to the end of my clutch cable with just very light resistance using my fingertips rather than the vice-grip/plier approach that I had to use to disassemble it.. and even when clutch arm/lever is fully pulled to maximum length the clutch is not engaging whatsoever, seems to me like something was put back together wrong but I’m no expert.............anyone care to give me some advice on how I can fix the problem myself before running the engine back to the dealership? If need be I can upload videos/photos to further help.... thanks everyone
sounds like the clutch arm on the case is not installed right ?. read the service manual to correct this.
1 - 2 of 2 Posts
