i am running out of options and not sure what to do anymore. i have an 2009 honda rancher 4x4 foot shift model. i have only put about six tanks of gas through it since i bought it. i have developed a really bad grinding noise from the rear end only when you make right hand turns. it does not grind while driving straight or turning left only when you turn sharp to the right. you can hear it and feel it throughout the bike. it has been into three different dealerships now and not one dealership can figure out what is causing the grind. they said the bearing all look ok, the shims are to spec and everything in the rear end looks normal. Is this a normal sound for this model ?or does anyone know what is causing this grinding noise?
