I have a 1984 trx200 that the starter just spins when you hit the start button. It had been making a little noise when I would start it and I checked out the bearing when one changed the cam chain and it seemed ok but after a few weeks of having it up and running it eventually wore out and now just spins the starter when I hit the button. So I'm pretty sure it is the starter clutch bearing. If so, my question is do I just need to replace the needle bearing or do I need to replace the whole starter clutch or atleast the bearing within the starter clutch? The reason I ask is because I've looked all over and I can only find the starter clutches for 86 and up models and not an 84. You can buy a kit on ebay that replaces the needle bearing and starter clutch bearing and race piece. But I cant find anything for the 84. Will the 86 starter clutch bearing and race work or if not can someone help me find the correct part that will?
