21 - 40 of 42 Posts
Discussion Starter · #21 ·
You said earlier that the motor turns over freely for a bit then gets tight. You mentioned the chain getting tight all the way around the sprockets when the motor became tight. Did you put a new chain in the motor recently? On the old sprockets? At this point I would want to know whether the oil pump is working or not too... maybe you can get to it? Any chance you put the oil filter in backwards?
I haven't replaced the t-chain and as far as i know it never has been. Im 99.9% sure i put the filter in correctly, although even after dozens of oil changes im sure i could make a mistake at some point ;)
Discussion Starter · #22 ·
I just re-read this thread and you mentioned having the side cover off to clean screens etc. Was there a reason for that? Crankcase have junk in it? Someone sink the motor? When you put the side cover back on, did anything get left out of there or did anything fall out of place (an o-ring, washer, oil pipe etc) as you were working? For some reason I have a sneaking suspicion that your motor wasn't getting any oil pressure...
The only reason i had the cover off was to check that screen. Figured while i had it apart for the piston i would check and clean both of the screens. They did have a nice collection of (im assuming) clutch material caught in them..... I keep my work bench as clean as possible so i should have noticed if any thing fell out while i had the cover off.
That piston hasn't been in there very long... and its getting chewed up. A few questions if I may...?
Was the top end under the rocker cover looking like it was getting lots of clean oil when you took it apart this time? Any discoloration on the cam or rockers from friction or heat? Any scratches on the cam lobes?
Is there any discoloration of the steel connecting rod at either end of it where it meets the wrist pin and lower bearing? No signs of high heat there?
How much wear is their left in the timing chain? Push the tensioner against the guide where it belongs and note the gap distance between the tensioner and cylinder.
Can you take a photo of the piston from the side so that we can see the ring set? Also a photo of the piston crown and combustion chamber?
Measure the piston-to-cylinder clearance and tell us what it is. Slide feeler gauges carefully between the piston skirt at its largest point (90 degrees from the end of the wrist pin) and the cylinder bore, while the piston is halfway down its normal stroke distance from the top. Start with a narrow feeler gauge and work your way up to thicker sizes until the fit feels snug and looks tight.
Careful, don't drop anything... fragile stuff.
Thanks,
Discussion Starter · #25 ·
Thanks,
Heres most of the pictures you asked for. The cylinder is currently apart so i cant get some of the specs and I dont have the time or space to assemble it tonight. Two things i noticed that i thought was odd while taking the pictures.... In the one picture it shows the rings with the gaps lined up, Im sure i had them spread out correctly... i guess they could have gotten spun since the disassembly. The other thing i noticed...i dont recall the weights on the crank being that blue the last time i had it apart.
Yikes! Those rocker arms dont look healthy! I think you topend isnt getting oiled properly. The cam bearing journals look completely normal. Could explain your topend seizure. I would be pulling that oil pump and measuring and inspecting everything!
Discussion Starter · #33 ·
As soon as i have time ill pull the oil pump and update you guys. Which part do you think caused the seize? Considering it only seized at certain points of rotation....after turning the crankshaft about half turn either way it would get tight.
I would still bet the piston caused the seizure. But lack of oil to the topend made all the problems worse. Those rocker arms and cam are in rough shape. I would be going over all the measurment of the oil pump that the fsm says to check. Any signs of wear i would change to be safe. We had to change the rotor on one of my buddies builds. I spec'ed out the oil pump on mine when i built it to be safe. Cuz lack of oil will wreck everything quick!
Alright, lets have a conversation. Those photos raise more questions (in my mind) than they answer. But I did see a couple clues worth investigating further.... more on those later...
I just read through three chapters (Head/Valve, Cylinder/Piston, Lubrication) of the service manual familiarizing myself with the motor, so I could talk about this. Again raising more questions than answers, since I haven't gotten enough information yet to point any fingers at anything and say "there... thats the problem". :-(
So I'm just gonna bounce stuff off ya and see what sticks and what comes back... and end with a recommendation.
A possible (or most likely) explanation for why the motor seized up while cranking it during a compression test is, because you may not have had it at TDC on the compression stroke when you took the valve cover off, then put it back on for the compression test? The cam or decompressor plunger or something may have moved up out of place slightly when the cover came off, causing a bind when you tightened the cover back up and cranked it over. My money is on the plunger popping out, but from here everything I say is speculation cause I can't look at any of the motor parts. The TDC procedure for valve cover removal is covered in chapter 8:
Now, what about that upper connecting rod discoloration? It looks like the wrist pin (either this new wrist pin or the old one, can't see this new one well enough in the photo) and the upper end of the rod has gotten pretty darn HOT at one time! It is discolored for what looks like about 1.25 inches or more down the rod beam, and the entire pin area is burned. Is that new wrist pin discolored from heat too? That don't look good... but the bottom of the rod looks like it hasn't overheated. I can't tell from the photos whether its been getting enough oil or not...
Answering your question about the side movement of the piston on the wrist pin... that is normal at the top of the rod. Thrust movement of the rod is controlled at the bottom of the rod where it connects to the crank throw. Any excessive slop at the bottom is a big problem, but not at the top. The bore holds the piston centered over the rod, not the rod itself.
Is the oil ring a one-piece ring or a three piece ring, that you assembled? If you assembled it, are the scraper rails fit into the expander right, rather than one of them put in alongside the expander? Is the oil ring free to move in the piston land or is it stuck? Does it seem to fit snugly in the bore? I have several more questions about that oil ring that can't be answered through a forum, so I'll leave it up to you to insure that it is good and that it is installed right and that it fits and that it works...
You mentioned the ring gaps being lined up in one of the photos... don't worry about that while the piston is out of the cylinder... The cylinder itself doesn't look very good to me. I see wear at the top of the bore and other clues that indicate to me that it should be mic'ed and if not in spec, bored to the next oversize as appropriate.
Now for some general commentary... The photos don't give me enough information... in some of the photos the cam lobes look a bit ugly, but in others not bad at all. Same goes for the rockers... didn't learn anything from them. Cam journals and the head look alright so its your call... was it getting enough oil up on top? Are the cam and rockers still good?
Also, in some photos I see fine black particles in the oil film on the parts. It looks like it could be grit from parts rapidly wearing and burning up from lack of oil, or it could be from old motor oil that was left in there for a few years too many... Your call.
I come away from all those photos with one nagging question... that seemed to be a common theme in most of those pics. It looks to me like there is a lot of grit in that motor. What that grit is composed of, or the source(s) of, I have no clue from here. Some of it is fine enough to be leaving stains... while some are particles. It looks like stuff is getting chewed up pretty quickly.
I'm not there to put eyeballs on it all and figure out what is going on... I know nothing about its history (and neither do you), so my best recommendation has to be this:
Pull the motor out of the frame and split the cases. Clean every part up in solvent so you can inspect it and proceed to make a list of things that need to be replaced/fixed/refurbed. Disassemble the head too, it probably needs valve seals at a minimum... Read the service manual until you understand it all, then put it all back together clean and right with appropriate lubes and sealants.
Hang in there...
Discussion Starter · #37 ·
I had a hunch that putting the valve cover back without having it set at tdc caused the seizure. What would cause the timing chain to get tight the whole way around whenever the the engine got tight (even after taking the tentioner our)? I thought only only the side of the chain that was holding the load would get tight.
Ill try and get some specs as soon as i finish up some other projects and make space to work.
Thanks for everyones help so far. :)
Discussion Starter · #38 ·
A thought i just had..... Would a weak oil pump cause oil in the motor to transfer over to the oil tank at a slower rate? If so that would explain why after adding 2.5 quarts of oil over a period of time and doing the run, sit, and check method for checking oil, the oil still didn't seem to show up on the dipstick.
Discussion Starter · #39 ·
Well now it makes sense why it locked up! Pull the bottom end out of the frame tonight and found this little guy sitting in the bottom of the engine next to the timing chain.... Must have fallen out when i pulled the valve cover and i never noticed it! Finally some progress.... :icon_ banana:
21 - 40 of 42 Posts
