1 - 2 of 2 Posts
Can someone help with some advice on how to pull the axles out of the front differential on this unit. I would appreciate some help.
I am also trying to remove the rear swing arm. Is there a special tool to take out the lock and hex socket nuts or is there some other work around on this? Any help is appreciated. Thank you. Jim
PICs Man Post PICs if they are anything like a car you just grab the axle ang give them a firm yank sometimes they come right out if they dont you might need to put a flat bar on each side of the inner joint and pry them out. I couldn't tell you about the swing arm with out seeing what you are speaking about.
1 - 2 of 2 Posts
