1 - 20 of 37 Posts
ok here is the porbleam my sis bayou 300 starts but it goes chug chuga for about 4minets then dies and thats us jumpen it off the cellanoied and gas is flowen out of the carb and into the tube that runes into the air box any ideals that would be the probleam pleas help fast
Float Needle sounds stuck or has trash in it
Yeah, I agree with Moose. Float needle stuck open and it's flooding.
nope it not stuke open and it is clean but it still go chug a chug as long as u want till u touch the gas then it goes blah and dies
Duh it's over fueling if you are dumping fuel in the breather tube the float is sticking....How did you check to make sure it wasn't sticking?
the carb was in kim dip for 1 week the flout was not shutten off got that set now the carb fix solenoid is dead the starter relay is hotter then the middle of fire
i shur hop 8th gread dose you more justus ten 7th
Discussion Starter · #10 ·
y u say that moose
Spelling errors and proper sentance structure is why he said that.
Oh, that's the problem? All this time I thought someone had switched the buttons around on his keyboard. LMAO.
Discussion Starter · #15 ·
i do just fine in speeling lol
Discussion Starter · #19 ·
well that makes me fill a lil better
It's deffinatly a stuck open float needle.
1 - 20 of 37 Posts
