so this quad has not been run in about 3 years, took the car apart and cleaned everything with carb cleaner spray, it now starts fine, and idles ok if I keep the choke on, but as soon as I take the choke off, I need to keep it running with the throttle, if I ride it for a while, it seems to do better. I would like to know the carburetion adjustment procedure, such as initial settings, what should the mixture screw be set at, ans so forth. Thanks.
