Just picked up a project machine yesterday. It's got some funny issues.
The guy I got it from had cut the ignition switch off cause he couldn't get spark. Only way he could do it was twisting Red, Black, Black with white together. If you do that you get spark
Is this due to a bad neutral switch? Green neutral light doesn't come on, and no voltage going to the neutral light while in neutral.
He was only using the kick start but I put a battery in. Same issue with battery but it's better than kicking it.
Now I actually can't even get it to fire but I think the carb might be dirty. It will only pop here and there even with ether.
