1 - 12 of 12 Posts
Seems like it is not getting gas. I pump the manual pump and it starts and runs for a short time, then dies. try to start it turns over but won't fire. Pump it manually and it starts but dies after running a short time.
Any suggestions????????:confused::confused:
Welcome to the forums. The carb probably needs to be taken off and cleaned.
Helmut thanks for the quick reply.
I had problems last year and took it to a repair shop. they cleaned the carb and overall tune up. I had it out a couple weeks ago and it ran like a champ. Rode it for a couple hours.
I'll try your suggestion
Thanks
BB1
need help 2
2004 honda 450
Gas coming out of a tube on the bottom of carborator. This tube is attached to the carborator and nothing on the other end. My brother has a 350 and has the same tube.
Turn the gas off and it stops. turn gas on or to reserve and it just pours out.
BB1
2004 honda 450
BB1
The float valve is stuck open and not shutting the fuel off when the float bowl gets full. The bowl is overfilling and running out the overflow.
Discussion Starter · #10 ·
2004 honda 450
BB1
Thanks Helmut!!
The float valve is on the side of the carborator (metal bubble)????
I took off the top of the carborator before this happened and it was bone dry. Didi not even smell like gas. I tapped on the float valve cover while trying to start. It started and then started pouring gas.
Any suggestions on how to get it unstuck?
BB1
The float valve is inside the carb. It is attached to the float. When gas fills the carb bowl, the float rises and the float valve shuts off the fuel inlet, stopping the gas flow into the carb bowl.
Here is a picture and diagram. In the first picture, you can't really see the float valve itself, but it's under the float where the arrow is pointing to. I circled the float valve in red in the diagram.
1 - 12 of 12 Posts
